alisonmcneilly
- Joined
- Dec 9, 2011
- Messages
- 69
- Points
- 16
My 2012 fiat doblo, I have been noticing a vibration through the steering wheel while turning at slow speeds. Any ideas what it could be? T
Both directionsAs portland_bill says difficult to answer. Is it one direction only, if so note where the steering wheel is exactly pointing at the time, then when stopped with wheel in same position check if tyre is fouling something, wheel arch inner plastic etc. can make a noise. However without hearing a noise and when it happens we are only guessing. In the past I have heard wheel bearings, drive shaft joints, faulty tyres, wheels coming loose, power steering belts slipping (obviously not on electric steering) if you were touching the brake pedal at the time it could be a worn brake pad catching the list can be endless. The one I liked was where we told the customer we had found the problem " it's the nut lose behind the steering wheel"![]()
Both directions. Car has had quite a lot of work done ar front track rods and another arm done as well as springs and mountsAs portland_bill says difficult to answer. Is it one direction only, if so note where the steering wheel is exactly pointing at the time, then when stopped with wheel in same position check if tyre is fouling something, wheel arch inner plastic etc. can make a noise. However without hearing a noise and when it happens we are only guessing. In the past I have heard wheel bearings, drive shaft joints, faulty tyres, wheels coming loose, power steering belts slipping (obviously not on electric steering) if you were touching the brake pedal at the time it could be a worn brake pad catching the list can be endless. The one I liked was where we told the customer we had found the problem " it's the nut lose behind the steering wheel"![]()
Pretty sure it's not strut mounts as I know that soundAgain as portland_bill suggested top strut mounts can make a noise in both directions ( I would describe as a mechanical grunting sound) and at low speed as when parking or manouvering, especially if it has been standing for a while parked up waiting for work to be done. With the bonnet up sometimes it is possible to put your hand on the top mount whilst it is being turned and feel the harshness, easier if at an MOT station sat on turning plates. It may not be possible to easily access them if behind trim etc. Another small point if it is that, and left for a while it can cause front spring failure as the noise is the spring jumping around on the Macpherson strut when bearing is seized. Sorry to be all doom and gloom, with all the years in the motortrade you often only see the problem cars with the drivers complaining about spending a couple of hundred pounds on the vehicle that gets them to work every day of the year, but will happily hand over a couple of thousand pounds for a two week holiday to a travel agent![]()
It's usually when I'm moving car on or off drive way so possibleCV joints usually show on full lock maybe going in a tight circle in a car park first one way then the other, though more of a loud clatter than a vibration as you describe.
