Hi, I have put up a couple of posts regarding gearbox oil level plug for my 2012 1.6 Multijet.
Having now done a bit more in depth research on the matter, and have identified the gearbox as a C635 type.
There is only drain and fill plugs on this box, and no level plug. So it's a case of drain off and refill only, 1.75 litre refill 2.0 litre from dry.
Obviously before undertaking the task you need to make sure that the fill plug loosens first otherwise you are in trouble if you can't budge it and you have already drained off!
