cusiphil
Hi guys
Help!!! After a few problems with van it failed to start, after using ecuscan I found 1701 fault, I had Ecu refurbed because of water ingress, and found a broken wire under pass light, which was fixed, van started run lovely, turned van and hasn't started since. I've fitted new Ecu again due to more water running over Ecu, this has now been sorted, still doesn't run. Ive had Ecu immo taken off thinking it was a immobiliser problem. Ive checked fuel pump in tank, ok. Filter cleaned and replaced, fuel is getting to the high pressure pump but not getting to the rail. Also in the dash there is a light with a car and lock on it. Ive stripped all the front off including the radiator to get better access, and have notice a wire with yellow plug end (2 wires) and both sockets have broken connectors inside of them. For the life of me I can't find where this wire Goes to!! It comes from drivers side close to top of radiator. Before I start paying silly money for high pressure pump, is there a repair kit, or do I need to change regulator switch connected to hp pump, and does anybody know where this wire goes
