General 2005 Scudo Central locking Help!
Derek M Walshaw
Remote central locking using fob stopped working. Thinking it was the battery, change that still no joy. So I looked at maybe a fuse has gone. I haven't a owners manual, but surprised that there no key diagram anywhere to explain what each fuse is for. So my question: is there a fuse for central locking, if so where it and a diagram appreciated. Everything else works as it should. Central locking works using key. The little red light near window flashes as it should.
Cheers All
Every thing worked until I had to change battery. You then have to reset central locking. You turn on ignition then work the fob buttons till the central locking works. It doesn't. Conclusion the fob is old and used and probably packed in. Cost £95 + VAT just to reset the fob. Haven't inquired yet how much the fob is, and won't.
