Panda 2004 Panda Dynamic
Just bought this 2004 Panda Dynamic, 1.2 as a little fixer upper to sell. Having had my 'MyLife' for over a year I have become quite attached to these cars. I'll post updates on this thread of it's little journey.
I've got another Panda, with 64,000 on the clock, I think that's quite the bargain!
I always liked the custard yellow, but I won't be keeping this unfortunately. It requires a bit of loving and once it's got it's fresh mot it'll be going away.
If you're interested, Follow it's journey with me on this
Whilst waiting for parts, started doing some tidying up jobs. Confirmed it is coilpack 1 that's buggered but they should be arriving tonight (15/10/25).
Cleaned up the throttle butterfly valve, had a go with the sandblaster with the battery stay. Wire wheeled and copper greased the top strut nuts/thread, cleaned up the coilpack brackets.
Gave it a quick wash, pretty impressed with how well it's came out!
Had a scuff on the nearside but luckily with a little bit of G3 Polish and a rag, got it all off!
Went back to the unit at night and gave the headlights a polish! Really impressed with how well they've came out!
FIXED! Firing on all 4 cylinders now!
Coilpack 1 (closest to firewall) was the issue, but just for peace of mind, I replaced the sparkplugs and HT Leads!
***HT LEAD ORDER***
If you're doing this and forget, the leads from the coilpacks in order from closest to firewall to bumper is 4 - 1, 3 - 2.
As in;
Coilpack 1 - Plug 4
- Plug 1
Coilpack 2 - Plug 3
- Plug 2
- Also changed the thermostat as it was a 10 minute job.
Fitted airbox back on and fired it up, no misfire anymore!! EML also went out, didn't even need to wipe any codes!!!
  • Like
Reactions: koalar
Decided to give the rear beam some TLC, needle gunned it, wire wheeled it where needed. Red oxidised it, epoxy painted it then used some undersealing on it!
Gave the brake drum shoes assembly a good clean with brake cleaner, gave the drums a slight clean and paint with VHT black.
This is going to be a good wee treat for someone!
Didn't really need them done BUT thought I'd do it anyway, front discs and pads changed! 😊
Gave front end/subframe some undersealing!
Hi folks,
I'm nearly at a stage I'll be MOT'ing this. Was just wondering if anyone could give me some selling advice?.
2004 Panda Dynamic, 64,500 miles.
Timing belt/water pump was done 2023✅
2X new ignition coils✅
New HT leads✅
New sparkplugs✅
Underside cleaned and undersealed✅
New front discs and pads✅
Bad point ❌️ rear bumper is cracked but no damage to the rear crashbar.
Would £1500 be too high a price to advertise? And would you recommend I source a new/colour matched rear bumper?
Thank you
Adam
  • Like
Reactions: koalar
Garages adding a warranty are normally a fair bit higher, plus they add a bit extra on top to sort out any part exchange
Private sale are normal quite a bit less
A thousand or near offer sounds about right to me
Got it's MOT booked for the 4rth November at a local garage!
Re-adjusted the handbrake cables, at the drums first then the adjustment nut at the handbrake.
Repainted the plastic trims
Painted the rocker cover, exhaust manifold heatshield and the engine mount. Certainly freshens it up!
  • Like
Reactions: koalar
Great work you've done there, lots of TLC The problem is now you've eaten away at your profit margin, but good luck with the sale anyway. (y)
Thank you!
Uch it was just a little project, more for myself. I've probably spent about £90 in parts so far. I still need to clean the interior 😷.
I'm just glad that hopefully someone can enjoy it for a while longer 😊
So I decided I'd give the Panda a small drive to make sure it was good for its MOT, but realised the steering felt, off? I took my hands of the steering wheel when accelerating and like a poltergeist, it started rocking left and right (centre top going to the 11 o clock position to the 1 o clock position). Then after approx 3 minutes, the steering went completely dead.
Checked the obvious;
Battery - charged and good ✅
Earth straps - good and clean ✅
Loose AUX belt - good ✅
Alternator - charging ✅
I was a bit puzzled but I actually stumbled across a post from 2015 on here regarding similar issue and it being the Torque Sensor on the steering rack. As none of the other 'probable causes' seemed to be the issue, I'm hoping this is it.
I managed to remove it without disassembling the steering wheel, lower cowling and 7 bolts, 1 big circlip and 1 small circlip.
Just waiting for new one to arrive then I'll update if issue is fixed.
I have a similar Fiat Panda Dynamic 2004 which has now 58,000 miles on the clock. I bought it in May this year without an MOT and needing plenty of new parts like brake calipers, exhaust and both front and rear springs & dampers plus a few more smallish items. But it all adds up. All I will say with hindsight is it would have been simpler, and easily just as good value, if I had bought a similar car with a year's MOT. And if I would have happily paid £1,200 and reckoned it a bargain. So £1,500 sounds reasonable ... especially if the bumper has been repaired. :cool:
Thank you Jamlax, I really appreciate that! I'll look into the bumper getting swapped! 🫡
So, today was meant to be the pandas MOT, however I changed the Torque Sensor but the power steering is still dead. I believe that's now indicating its the electric motor?
I'm frustrated as I thought I was onto a winner, but I'm still happy to get a used steering column and swap everything over.
Hopefully get it back on the road for new year.
  • Like
Reactions: koalar
