Has anyone mentioned the speaker amplifiers which have give various car makers sore heads resulting in the cars being called in for reprogramming. Parasitic drain of course.
Good point, however my speakers are connected direct to the radio.Has anyone mentioned the speaker amplifiers which have give various car makers sore heads resulting in the cars being called in for reprogramming. Parasitic drain of course.
Russell Hi russell said:https://www.12voltplanet.co.uk/split-charging.html[/url]
Is it possible to back probe the HD relay with multimeter to confirm that
it is functioning as it should. My philosophy is assume nothing but check
everything.
John
Hi russell,
I'd agree with you about your radio passing 10mA, that well within range,
and not your problem. There are afew ways to check amp draw, and you've
opted to remove fuses and check with multimeter. I've always opted the
other direction, leave all fuses in place and check each fuse on mvolts.
Sorry to bring it up again Russell, but this method has never failed me yet.
And its quicker as well.
You mention that your system is the NO.2 link. https://www.12voltplanet.co.uk/split-charging.html
everything.
John
Unfortunately not. It has a push button to check the voltage but only with a three level bar-graph display. I'll have to see about fitting an alarm.As a matter of interest does the control unit (PC 100) notify you when the engine
battery loses voltage due to your amp draw. Does it blink a warning light or a sound
buzzer alert?
No electric step although there is provision for connecting one in the distribution box for the domestic side of things.Do have other devices such as an inverter (which may still be turned on enough it not being used)
An electric step which might not have closed properly resulting in current draw.
Reversing camera. I'm not too sure if any of these devices are covered by the
control unit.
Nice looking Campervan John. Is that a Dutch registration?I unfortunately do not have a system like yours. Mines a 92 Ducato Weinsberg
Imperiale 7 meters long. Like one in this link
https://picturepush.com/public/7950952
Back then electonic components were just coming to the fore.
John.
Well, I'm a retired electronics development engineer but still learning about modern vehicle electrics.From your posts you are obviously highly competent to sort out electrical issues so this one must be well outside the box.
Thanks, that's something to look out for. Yes, I much prefer the Avo 8 but have to make do with Chinese test equipment now.I'm reminded of a fault many years ago on a car whereby the battery would drain overnight. After some head scratching I noted that the alternator was permanently connected to the battery and changed this as a measure of last resort (this was before the era of ÂŁ10 multimeters and I didn't posses an Avo!)
This cured the fault so I guess that the regulator had developed some sort of short.
I replaced the old 75 W panel a couple of years ago after it detached itself and disappeared on the motorway! I now have a 150 W panel which, as you say keeps the leisure battery topped up sufficiently, particularly here in in France near the Spanish border. It is connected, via the controller, to the leisure battery so doesn't charge the engine battery.Get a flexible 100 watt solar panel and glue it to the roof with a small pwm charge controller. Sever the link to the vehicle or put a manual switch in to use if needed. The panel will keep your leasure battery good all the time with led lights and other incidentals. With a 100 amp hour battery we can keep a nominal 60w fridge going too.
Russell.
I've had one of these* for some years thus enabling any surplus solar power to charge the vehicle battery. Consequently I haven't ever needed to charge the vehicle battery separately even during the winter months (but then of course I've only got the 'normal' parasitic drain!)
* http://www.cbe.it/en/csb2/
No.Hi Russell,
Does your on board battery charger have an internal fan?
What I meant was fitting an isolator switch something like this to the engine battery so that I can easily disconnect it when parked up for a few days without mains power. It is at the engine battery that the current drain is being measured.Fitting an isolator switch would probably do the job, I'm assuming that's reconfirming
the drain source is originating from the leisure battery side.
Yes, that looks as if it might do the job. Any idea what voltage drop it gives?I've had one of these* for some years thus enabling any surplus solar power to charge the vehicle battery. Consequently I haven't ever needed to charge the vehicle battery separately even during the winter months (but then of course I've only got the 'normal' parasitic drain!)
