Hello! Excited new owner of a 1965 500D
As I'm checking out what's working well, and what could use some love, I've discovered that one of the front turn indicators is not functioning. Specifically, the parking light works but the turn indicator does not. I've done all the usual checks and traced it down to a broken contact inside the indicator itself. (You may be thinking "just clean the contacts first!" and as I was going to do that discovered the broken contact)
So now I need to get a replacement indicator, but I am having a lot of trouble finding a replacement indicator online that has 3 (barrel) connectors on the back to make use of a dual filament bulb. From the wiring diagram I glanced at, the connectors are for Parking | Ground | Turn wires. However, all of the indicators I can find online seem to only have two connectors. Is this because after-market indicators switched to grounding to the chassis using the trim screws and eliminated the ground wire connection, or that most of the indicators I can find are for the UK market where (as I understand it) they do not use a dual-filament bulb and only use the indicator for the turn signal.
Thanks in advance!
Thanks in advance!
- Model
- 500D
- Year
- 1965
