2 things !
2 things !
E
Emma
1. My rear window wiper has just stopped working, does anyone have any ideas without me having to take into into fiat ???
2. I have a 1.8 HLX 1998, should i have remote central locking and alarm ??? because when i press the little button on my key it doesnt lock the car, only if i actually put the key in the door .
can anyone help me ???
AMAZING!!!!!!!!. My car is exactly the same as your except (1996). My car also suffers from these two problems. I went to Fiat to enquire about the alarm and right enough I should have had one. However they were unable to tell me there and then what was wrong. They suggested the following steps
1. Get both remote keys reset (£30 each)
2. Get new siren elemant and check wiring approx (£135)
3. Or the whole system may need replacing a colosal £500 + V.A.T
I was told that if the key reseting or step 2 were not effective then I would not get a refund and so basically I could have wasted money. Not surprisingly I decided to opt out.
P.S - I was also told this was "An extremely common problem of epidemic proportions"?!?!?!?!?!
Good Luck.
Liam
How bizarre...
My alarm problem is a bit different... 1997 R Reg 1.8
The Keys works for central locking... (Have you checked batteries / reset / taught the system etc...) but the ALARM does not set.... No flashing light / no siren / Nuffink !
Its not the 'key' in the fusebox is set to off.... I've checked that.... its just it doesn't work....
Rear wiper fix
I had the same problem on my rear wiper. Its just dirty contacts. Take the cover off the back so you can get to the electrics and just give it a squirt with switch cleaner and a wipe with a clean rag - works a treat now.
A
1
11K
Angelo
A
N
6
334
Sabre 23
S
M
2
177
marko
M
M
6
263
ROBIN
R
I
6K
I
