Technical 2 litre twin cam
tcc
does anyone have any power figures for the 2 litre twin cam engine, any info would be greatly appreciated
engine code 182A1.000
5 cyl 20v 1998cc
bore 82mm
stroke 75.65mm
compression 10:1
max quoted power (pre 99) 108 kw, 147 bhp @ 6100 rpm Later models 155 bhp.
peak torque 186 nm, 19 kgm @ 4500 rpm
If you need any info on the original alpha 2000 TC engines let me know.
thank you very much pole cat, most informative. do you have any tuning tips for it as i have just bought a westfield with this engine in
A five cylinder twin cam... in a westfield... cool, we only ever see them with a 4age (toymota) or similar over here (australia)
4 cylinder Fiat twin cam 2000 is a very different animal...
yea its the 4 cylinder sos to disappoint fiatfactory
well if its a four cylinder twin cam then the specifications are a little different than polecat described....
without knowing the ID of the engine, (fiat, lancia, from a 131 or a Beta etc)
bore...84mm
stroke...90mm
compression ratio (probably) 8.9:1
output (between) 112bhp @ 5600 (132) and 119bhp @ 5500 / 130.5 lbft @ 2800 (lancia beta)
these are quoted outputs for carburettor engines, naturally aspirated. (also available in Volumex (supercharged) form
there are also a couple of variants, ie late injected cars and also vehicles with a "reverse" direction flow.... the head was reversed on the block putting intake/exhaust on opposite sides to "normal"
there are also many variants of cylinder head, different valve sizes, port sizes and camshafts from the factory.
If you have an engine ID or type (found stamped above the oil filter mounting block) then I may have more information for you.
If you want more output, how much money do you have to spend???
To build a 150hp output engine is one figure, but to go past this, its about 20% more money for every 10hp, so a 200hp output engine will be about double the price, naturally aspirated (but is acheivable and driveable in a road car) if you want to turbo the car, lots more $$$ but lots more ponies too.
16v heads from the late type engines (tipo, integrale) fit the early blocks, but need a fair bit of fiddling to get everything right..... check out this site
http://www.beardmorebros.co.uk/website pages/new_project_engine_page1.htm
for more ideas....
SteveC
cheers fiatfactory most informative and i'll go check that link out, must say would like to turbocharge it
