Technical 2.8JTD 2002 potential wiring potentiometer fault
zombieites
Does anyone know a reputable mechanic/garage that can fault find a long tem problem on 2.8 jtd 2002 motorhome
Hi don't know where you are but I had a problem when touring the north and was treated like a human being which is very rare in a garage I went to DonaldMacKenzie's in inverness and they repaired my 2009 ducato motorhome
Cheers cosworth101
In nw cheshire way, people I have tried have genuinely doing there best but the fault unfortunately still lingers, driving ok for a time then complete loss of revs at engine, no revs at all, can be stranded in middle of road, nightmare
Sorry mate I'm in south west scotland do you have any fault codes coming up
Fault codes, (read by mechanic) seem to vary from turbo pressure sensor (replaced) to fuel reg (replaced), now moved onto wastegate actuator, still losing revs, and power loss, thinking now accy pedal , not sure, potentiometer
Wasn't having a go at you, you're mechanic sounds like he's grasping at straws, changing parts without having a clue. Wastegate actuator can be tested with a vacuum pump he should have one. Do you have overboost, underboost? A graph of boost, pedal %, desired fuel pressure, actual fuel pressure would have you on the right track the instant it loses power.
Great advice, but this is precisley my point, need a mechanic to read and understand data from ecu
