Technical 2.4 exhaust manifold part numbers
kidderminster
Help please, my Croma has been at the garage for weeks due to snapped exhaust manifold studs, I am now being told the manifold is warped by 1.5mm and needs replacing or skimming. According to 2005 Eper on here the part number in 2005 was 55202905, but can anyone tell me if on a later version of eper 55202994 is also the same part ? I have found a used one with that part number ! The Local fiat dealers are shut and so are shop4parts. Thx David
Thx to both of you for your quick replies. I will try and find out if the manifolds fitted to the 2.4 Croma's are stamped 55202905. Lots of 2.4 20v JTD manifolds which state they are part no 55202994 are being advertised. Below is one saying its for the 2.4 Croma. My mechanic has had a hard job trying to fix my car, had to remove alternator to remove exhaust manifold, it was leaking due to 4 studs/bolts being broken (2 on each end of manifold). 2 more studs broke when being removed.
https://www.ebay.co.uk/itm/55202994...360944&hash=item593f846249:g:FDgAAOSw0Gxd8jyb
Anyone got a spare 2.4JTD exhaust manifold ?
How far back does the manifold spec go.. bravo:marea era..?
Alfa models only:
55202905 EXHAUST MANIFOLD
Famiglia: FF36 - VARIOUS PARTS WITH CONTROLLED MANAGEMENT
Availability: Product that can be ordered Minimum quantity per package: 1
Macro-family: B Discount code: B
Weight (grams): 3800 Listed price(1): 512.43 GBP
Measurement unit: Num Price including taxes: 614.92 GBP
Product previously in use
FIAT - 2T CROMA (2005-2010)
ALFA ROMEO - X8 159 MY11 (2010-2011)
ALFA ROMEO - X3 ALFA 159 (2005-2008)
ALFA ROMEO - X9 ALFA 159 (2008-2010)
ALFA ROMEO - X4 BRERA COUPE' (2005-2008)
ALFA ROMEO - 12 BRERA COUPE' M.Y. (2008-2010)
ALFA ROMEO - X5 NUOVO SPIDER (2006-2008)
ALFA ROMEO - 13 NUOVO SPIDER M.Y. (2008-2010)
Thx people. Sadly I don't know the part number on my manifold as the garage sent it to the machine shop to see if it can be skimmed prior to me looking for another used manifold. What I have found out is that this is a common problem on the 2.4JTD engine as the manifold is so long and badly designed.
