Hi was told about this site by one of the guys on tipo16v so here i am and here is my tipo. hope u like!
hi.kimi1984 said:Hi was told about this site by one of the guys on tipo16v so here i am and here is my tipo. hope u like!
what sh*t did you have with it? mine scrapped its bottom endkimi1984 said:hehe it was like that when i bought it. annoying but nothing i cant sort out. had so much s**t wid this car just glad to be mobile now!![]()
all the spring does is stop the shocker from oscilating.get the shockers on asap.i hope with the lightened flywheel,you had the flywheel,crank and con rods balanced as one unit? if not,you will have bottom end problems.kimi1984 said:had lotsa work done to the engine: cams, port polish, pistons, different vernier pulleys, lightened flywheel, air filter and a gas flowed (whatever that does lol)! been lowered not sure how much but its on springs only and it stupidly bouncy so i think coilovers for cars birthday! needs work done however to get it running 100%.
yes. some engine builders will not touch them.yet others say no problem with them.mind you,there are engine builders and rip off merchants.i would ask your engine builder if the bottom end was balanced or not.kimi1984 said:yep. luckily when i bought the car i got all the reciepts so i rung the garage where it was done and asked them what had been done as i was a bit suspect. they said that everything has been done perfectly and that they was never going to work on a 2.0 tipo again as they are such sods! is this true??
yer tell me about it. my m8s got a fezzie turbo, he sent his car to get done and the gits replaced with slighty modded engine with a standard one! cant trust no-onne theses days!sumplug said:yes. some engine builders will not touch them.yet others say no problem with them.mind you,there are engine builders and rip off merchants.i would ask your engine builder if the bottom end was balanced or not.![]()
