homeward Brain stopped play Parked in the garage Written a guide Joined May 22, 2012 Messages 6,303 Points 1,867 Location On the hard shoulder... Jul 13, 2013 #1 Seems pretty honest.... This post contains affiliate links which may earn a commission at no additional cost to you.
Giacosa Patron member Joined Sep 9, 2004 Messages 1,685 Points 522 Location Dundee Jul 13, 2013 #2 No rust on its fail sheet which must make it worth saving. The broken rear coil springs are odd. Hardly a common problem with Pandas.
Most Easterly Pandas Speed Reader of the Year! Parked in the garage Written a guide Joined Aug 15, 2007 Messages 44,236 Points 7,383 Location Norwich, Norfolk Jul 13, 2013 #3 Rear spring is only about a 5 / 10 min job to do as we'll iirc
VmanC The Panda whisperer Parked in the garage Joined May 6, 2009 Messages 5,830 Points 1,664 Location Alton, Hants. Jul 13, 2013 #4 Giacosa said: No rust on its fail sheet which must make it worth saving. The broken rear coil springs are odd. Hardly a common problem with Pandas. Click to expand... Ah but isn't the failure sheet from 2010? Plenty of time for rust to have developed since.
OP OP homeward Brain stopped play Parked in the garage Written a guide Joined May 22, 2012 Messages 6,303 Points 1,867 Location On the hard shoulder... Jul 20, 2013 #5 Three bids; and £175. Doesn't seem a lot, considering most of the fixes aren't too expensive... -- especially if you do them yourself....
