Panda (Classic) 1991 Panda 750 Mania (needs clutch)
The East Midlands, Derby.
>>>Here<<<
HERE WE HAVE FOR SALE A MUCH LOVED AND, UP UNTIL VERY RECENTLY, VERY RELIABLE MODERN CLASSIC 1991 FIAT PANDA 750 MANIA
MOT'D UNTIL DEC 2016
NOTE NEW CLUTCH REQUIRED SOLD AS SPARES OR REPAIR
SOLD AS SEEN, WILL NEED TRAILER TO REMOVE
CHEAP CLASSIC CAR INSURANCE, LESS THAN £100 LAST YEAR
PICS OF INTERIOR AND RUST PATCHES TO EXTERIOR.
NOT MINT BUT WAS WELL KEPT UP UNTIL RECENT BREAKDOWN WHICH WAS THE ONLY TIME IT HAS FAILED ME IN 2+ YEARS
looks like it would make a very nice little panda for some one!
Registration number: K889JMB
  • Vehicle make FIAT
  • Vehicle model PANDA
  • Date first used 25 August 1992
  • Fuel type Petrol
  • Colour White
MOT history of this vehicle
  • Test date 30 November 2015
  • Expiry date 29 November 2016
  • Test Result Pass
  • Odometer reading 79,219 miles
  • MOT test number 1732 1652 6542
  • Test Result Fail
  • MOT test number 1103 5423 8351
  • Reason(s) for failure
    offside front Front wheel bearing rough when rotated (2.5.A.2)
  • Test date 12 November 2014
  • Expiry date 11 November 2015
  • Test Result Pass
  • Odometer reading 66,321 miles
  • MOT test number 8053 1611 4351
  • Advisory notice item(s)
    Offside Front Tyre worn close to the legal limit (4.1.E.1)
    Nearside Rear Shock absorber has a light misting of oil (2.7.3)
    Offside Rear Shock absorber has a light misting of oil (2.7.3)
  • Test Result Fail
  • MOT test number 6570 5671 4331
    Nearside Front position lamp(s) not working (1.1.A.3b)
    Offside Front position lamp(s) not working (1.1.A.3b)
    Nearside Stop lamp not working (1.2.1b)
    Offside Registration plate lamp not working (1.1.C.1d)
    Offside Headlamp not working on main beam (1.7.5a)
  • Test date 7 November 2013
  • Expiry date 6 November 2014
  • Test Result Pass
  • Odometer reading 56,180 miles
  • MOT test number 5396 3131 3358
    Nearside Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
    Offside Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
    rear number plate starting to deterioate
    n/s/r tyre cracked
  • Test date 6 November 2013
  • Test Result Fail
  • MOT test number 7291 0001 3308
    Nearside Headlamp aim beam image obviously incorrect (1.8.A.1b)
    Offside Headlamp aim beam image obviously incorrect (1.8.A.1b)
    Service brake: efficiency below requirements (3.7.B.7)
    Parking brake: efficiency below requirements (3.7.B.7)
    Nearside Rear rear brake recording little or no effort (3.7.B.5a)
    Offside Rear rear brake recording little or no effort (3.7.B.5a)
    Nearside Rear rear parking brake recording little or no effort (3.7.B.6a)
    Offside Rear rear parking brake recording little or no effort (3.7.B.6a)
    Offside Rear Tyre worn close to the legal limit (4.1.E.1)
    both front headlight bulbs held in with tape
    n/s/r tyre cracked
  • Test date 12 September 2012
  • Expiry date 11 September 2013
  • Test Result Pass
  • Odometer reading 48,659 miles
  • MOT test number 9960 9645 2266
    Nearside Front Tyre worn close to the legal limit (4.1.E.1)
    Nearside Rear Shock absorber has a slightly worn bush (2.7.4)
    Offside Rear Shock absorber has a slightly worn bush (2.7.4)
  • Test date 7 September 2012
  • Test Result Fail
  • Odometer reading 48,612 miles
  • MOT test number 4189 1155 2257
    Nearside Front Seat belt anchorage prescribed area is excessively corroded (5.2.6)
    Offside Front Seat belt anchorage prescribed area is excessively corroded (5.2.6)
  • Test date 6 August 2012
  • Test Result Fail
  • Odometer reading 48,387 miles
  • MOT test number 8876 8991 2233
    Front Exhaust has a major leak of exhaust gases (7.1.2)
    Windscreen washer provides insufficient washer liquid (8.2.3)
    Offside Inner Rear Subframe mounting prescribed area is excessively corroded (2.4.A.3)
    Nearside Rear Lower Shock absorber has an excessively worn bush (2.7.4)
    Offside Rear Lower Shock absorber has an excessively worn bush (2.7.4)
  • Test date 19 August 2011
  • Expiry date 31 August 2012
  • Test Result Pass
  • Odometer reading 43,305 miles
  • MOT test number 3990 9103 1254
    Front Exhaust has a minor leak of exhaust gases (7.1.2)
    Nearside Front coil spring corroded (2.4.C.1b)
    Offside Front coil spring corroded (2.4.C.1b)
    Nearside Rear coil spring corroded (2.4.C.1b)
    Offside Rear coil spring corroded (2.4.C.1b)
    Oil leak
    inner sills corroded
  • Test date 24 August 2010
  • Expiry date 31 August 2011
  • Test Result Pass
  • Odometer reading 43,283 miles
  • MOT test number 4841 9643 0252
    Nearside Front Shock absorber has a light misting of oil (2.7.3)
    Offside Front Shock absorber has a light misting of oil (2.7.3)
    front number plate cracked
  • Test date 18 August 2009
  • Expiry date 31 August 2010
  • Test Result Pass
  • Odometer reading 39,838 miles
  • MOT test number 2426 8003 9277
  • Test date 1 September 2008
  • Expiry date 31 August 2009
  • Test Result Pass
  • Odometer reading 37,215 miles
  • MOT test number 3918 1524 8230
  • Test Result Fail
  • MOT test number 7902 2564 8265
    Offside Headlamp not working on dipped beam (1.7.5a)
  • Test date 12 July 2007
  • Expiry date 17 July 2008
  • Test Result Pass
  • Odometer reading 36,339 miles
  • MOT test number 1148 5349 7152
  • Test date 4 July 2006
  • Expiry date 17 July 2007
  • Test Result Pass
  • Odometer reading 35,942 miles
  • MOT test number 6545 8518 6170
    Rear Exhaust has part of the system slightly deteriorated (7.1.1a)
  • Test date 18 July 2005
  • Expiry date 17 July 2006
  • Test Result Pass
  • Odometer reading 35,365 miles
  • MOT test number 8901 7919 5151
    Nearside Rear Suspension arm corroded but not seriously weakened (2.4.G.1)
    Offside Rear Suspension arm corroded but not seriously weakened (2.4.G.1)
    Nearside Seat belt anchorage prescribed area is corroded but not considered excessive (5.2.6)
    Steering system has slight free play detected at steering wheel (2.2.A.1b)
    O.S rack boot damp
    rear tyres cracking
    coolant leaking
Pretty extensive history.
Looks like a 5 speed 'box on there too, really plush for a 750.
It would be if its a Mania, all Mania's are 5 speed, I assume it was Fiat trying to get rid of the 5 speed boxes that they had left which still used rod change as from late92/93 onward they're cable change.
This one should have a clock though, Fiat must've forgot to put one in that day :rolleyes:
  • Vehicle make FIAT
  • Fuel type Petrol
  • Colour White
  • Test Result Pass
  • Test Result Fail
  • Test Result Pass
  • Test Result Fail
  • Test Result Pass
    n/s/r tyre cracked
  • Test Result Fail
    n/s/r tyre cracked
  • Test Result Pass
  • Test Result Fail
  • Test Result Fail
  • Test Result Pass
    Oil leak
  • Test Result Pass
  • Test Result Pass
  • Test Result Pass
  • Test Result Fail
  • Test Result Pass
  • Test Result Pass
  • Test Result Pass
    O.S rack boot damp
    rear tyres cracking
    coolant leaking
Many thanks for this post Sir. (y) I snapped it up myself.
