well i can swap them headlights around.. i need a set of marbella headlights. mind you, mk1 and mk2 panda headlights are different are they?
Yep, Mk2 Panda ones would look better though. MK2 bumpers probably would aswell.
Having worked in a car restoration business I know how much it costs, you could easily spend £12,000 on any car if you want it totally stripped, rust repaired and repainted all over including the inside and underneath and not do any of the work yourself, there is alot of work there. A shame this one was ruined at the very end by fitting the Marbella stuff, still it is not hard to change the bumpers, headlights and interior so presuming all the bodywork has been done right it would not be hard to make it a very nice proper MK1
m.breaker said:Fiat panda 83 reg 42,000 miles very clean new exhaust and brake lines the bonnet needs painting as to some fire damage caused from battery leads to alternator also some wiring looms need replacing there is little rust and needs a distributor it’s is though very clean and a ideal project
uk bidders only
cash on collection
For more info tel joe *07984 306013
MOT History said:RUC671Y FIAT PANDA
Check another vehicle
Colour Brown
Fuel type Petrol
Date registered 30 June 1983
MOT expired on 19 March 2013
Get an MOT reminderwhen the vehicle's MOT is near its time for renewal. (Opens in a new Window) by email or text.
If you think the MOT expiry date or any of the vehicle details are wrong, contact DVSA.
Mileage recorded at test, parts failed or had minor problems
Date tested 20 March 2012
Pass
Mileage 42,407 miles
MOT test number 4869 9088 2013
Test location unavailable until further notice
Expiry date 19 March 2013
Date tested 16 March 2012
Fail
MOT test number 9173 7637 2089
Reason(s) for failure
What are failures?
- Offside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
- Offside Rear rear brake binding (3.7.B.1)
Date tested 7 October 2010
Pass
Mileage 42,159 miles
MOT test number 3322 6058 0294
Expiry date 6 October 2011
Date tested 20 September 2010
Fail
Mileage 42,139 miles
MOT test number 5944 7376 0212
Advisory notice item(s)
- Offside Windscreen washer provides insufficient washer liquid (8.2.3)
- Nearside Headlamp insecure (1.7.3)
What are failures and advisories?
- unable to test off side rear hub bearing with brake binding
Date tested 11 August 2008
Pass
Mileage 42,072 miles
MOT test number 9120 8402 8246
Expiry date 10 August 2009
Date tested 18 July 2007
Pass
Mileage 42,048 miles
MOT test number 7547 2929 7152
Expiry date 17 July 2008
