Technical  1100 uno modifications
1108 fire engine can be tuned to abaut 130HP(look at cc kit car).
You must change almost evrything, withaut block and head:
- pistons
- rods
- crankshaft (maybe not)
- camshaft (about 280 deg)
- flywheel
- valves
- valves spring
- full exaust system
- intake system
- full injection system (dual throttle bodies or invidual throttle bodies, ecu, high flow injectors, better manifold)
and many other things, but this will cost very very much, and also using such kind of car is expensive
Home made tuned fire engines have about 80HP. Head is changed for punto 1.2 75HP head(with 886 camshaft) with multipoint injection system. Also exaust and intake system must be changed for better performance.
