I would be extremely gratefull if someone could help me out with this one!:worship:
I have a 1989 Italian registered Tipo 1100 DGT, after the engine has been running for about 5-10 mins it cuts out, switch off ignition and on again and it starts but only for a few seconds, sometimes I have to do this 10 or 15 times before the problem clears. It cuts out cleanly so I don't think its fuel but I have replaced the fuel pump and filter just in case. It seems to be worse when the weather is cold and when it is running fast Once the problem has cleared it will run all day perfectly well:bang: Unfortunately here in Kefallonia (Greece)the local mechanics haven't got a clue! HELP!!
NB The fuel filter only looks full afterit has been idle for some time otherwise there just seems to be a very small amount in the bottom when the engine is running, is this normal?
