Kev_marea
Hi there.
I need to remove the cylinder head from my 100TD Marea. In order to do that one of the first things I need to do is remove the TB cover, but there is an engine mount right in the middle of the TB cover like a black metal arm about 4 inches long going backwards to a mount near the engine compartment bulkhead.
Anyways, I initially thought it might need jacking up to remove this mounting arm, but now I have seen there is another engine mount at the base of the engine at the TB end. So there are 2 mounts at the TB end.
Does this mean I can safely undo the top engine mount without the need for jacking support?
TB = Timing Belt not Throttle Body!
