Technical 100HP gearbox oil change
Rockrabbit
Is it easy enough to change the Gearbox / Transmission oil DIY? My gears feel a little sticky (not as smooth as they were before).
Any useful tips? What oil do I use? Should I flush out the old Oil?
Thanks,
H
Drain the old oil when it's warm so it flows out better.
I use FUCHS TITAN SINTOFLUID SAE 75W-80 Manual Transmission Fluid. £22 for 2 litres from opie oils on eBay. It's fully synthetic.
Don't use an EP oil (extreme pressure) as it'll knacker your synchros.
How much oil should I put in? Do I fill until the oil dribbles out the filler cap?
H
I done mine a while back, drained the fluid out, all of about 800ml come out, thought oh, it must have been low, filled it up and the same went in! Seems to drive alright except the crunchy 3rd if you're a bit quick.
