1.9JTD Radiator + Fan Wanted
A
Al-armed
As above.
My car is nearly finished after a front end bump the only thing I'm having probs with is the radiator and fan. for some unknown reason it's different to the 1.9td bravo.
Here is a picture of the radiator one hose is top right the other is bottom left.
www.autoarm-ne.co.uk/pic/rad.jpg
Any help welcome,
Already tried partfinder :)
Cheers Paul
Serial No.
Paul, bit difficult to tell as the diagramaticals show it from the other side, but if I take into consideration the angle of the pipes, I think the part number for the rad is 46547089 and is unique to the JTD. The fan, according to your pic is 46537247.
If you e-mail me your serial number I can confirm the above. If it is these two units they are £213 and £182 for the rad and fan respectivley from Fiat.
Serial no is on the front susp turret starting ZFA182000
Cheers
Nige
:-o
Thanks Nige,
Thats what I was afraid of, So I thought of posting on here for a second hand one, But my options are running out:-(
Thanks for the reply hopefully paramedics will be here soon.lol
Paul
before you pass out
This set up was not just on the bravo....it was also on the Marea diesels as well and others across the range. Confirm your s/n and I can tell you what else it fitted.
Nige
Totally different from the TD's
At least a TD radiator won't fit. It looks complete different from mine in the TD75 Brava which is fitted with 2 fans.
Marc
C
7K
Carroll
C
R
805
R
A
9
820
B
