firedawg333
- Joined
- Jan 4, 2015
- Messages
- 17
- Points
- 58
Hi Folks,
My lovely local garage changed my cambelt and water pump but did not tighten up the bolts on my camshaft sensor resulting in vehicle not starting. On further investigation the bolt had come out and bent part of the pulley between the sensor and it is now rubbing slightly so I just wondered if any other make ie Alfa Vauxhall with the 1.9 JTD engine camshaft sprocket/pulley call it what you will will fit as i have found an Alfa one for £20 as opposed to £40 ?
Of course the garage won't admit to anything ven thought they only fitted the cambelt two months ago.
Mark
Mark
