Technical 1.9D not starting
ryn079
Malta
Hi guys,
after buying a 1.9D with a broken belt, I changed the bent valves and skimmed the head. I aligned the timing marks and fit a new belt.
The problem is that the car does not want to start. I know that there is a solenoid valve, but how can i test it?
This is the presumed valve.
Please help as i need the car urgently.
Thanks.
Ryan from Malta.
Valve tested but car still does not want to start!
Please help!!!!
I haven't done a compression check, but when i opened the engine, pistons seemed in excellent condition and as i said the cylinder head was re-built!
Ryan
I re-built engine myself, and aligned marks present on engine for timing belt fitting.
wouldn't the valves go onto the pistons if timing is incorrect?
No, you can have a few degrees each way without piston-valve contact. If the belt goes or slips too far then yes the engine is interference - as you unfortunatly have found out.
Hi guys,
i just wanted to inform you that the problem was that there was air in the fuel injection system.
I bought one of these hand pumps, installed it on the feed line to the filter, removed the stop solenoid valve, pumped the hand pump a couple of times till all the air was expelled, re-installed the stop solenoid and the car fired!
Thanks a lot for trying to help Hellcat.
Ryan
