OK, to conclude this (neverending) story.
Sluggish behaviour was caused by combination of EGR valve being stuck from time to time and dirty/faulty MAF sensor.
The power loss (loads of black smoke) below 2000-2200 RPM was definitely caused by faulty EGR valve as I got it cleaned at the service, and now that problem is gone
Then, I was left with general sluggish behaviour, so I disconnected the MAF sensor again and I could notice the improvement again. The problem was, when I tried to determine the problem in the first place, during MAF connect/disconnect tries, EGR valve began to stuck, so I was completely confused.
And now, I tried to unscrew MAF sensor, only to realize that screw head is not the 'security torx 20' (torx with a small circle pin in the middle) but something similar, the 5-way star torx with a pin. There is no way I can find a bit like that, so i'll just have to force it with some kind of clamps.
Again, thank you for your replies.
