capricougar New member Joined Jul 7, 2009 Messages 26 Points 8 Location co durham Dec 11, 2010 #1 Done the brain reset, cleaned the inlet, checked for loose cables, still wont tick over, where is the tick over adjuster??? Any Help appreciated...
vladof Light Seeker Written a guide Joined Jul 23, 2008 Messages 873 Points 143 Location Bucharest Dec 11, 2010 #2 Does it start and then stall or doesn't start at all?
OP OP capricougar New member Joined Jul 7, 2009 Messages 26 Points 8 Location co durham Dec 11, 2010 #3 vladof said: Does it start and then stall or doesn't start at all? Click to expand... Starts no bother,but stalls,when pulling up to junctions etc then will re start no bother ,then hunts for idle.gotto keep revin to stop cuttin out then sometimes no bother got me beat now!
vladof Light Seeker Written a guide Joined Jul 23, 2008 Messages 873 Points 143 Location Bucharest Dec 11, 2010 #4 Did you do a throttle relearn? Last edited: Dec 11, 2010
neonglow Member Joined Jul 12, 2010 Messages 347 Points 53 Dec 11, 2010 #5 Spray some WD40 on the throttle flap joints. Did you clean it propertly? Another reason could be the MAF, try disconnecting if nothing works.
OP OP capricougar New member Joined Jul 7, 2009 Messages 26 Points 8 Location co durham Dec 11, 2010 #6 did the throttle re set,where is the maf sensor??
