1.8 16v question
1.8 16v question
M
matt
what engine is it dohc / vvc or what.
ive heard so many different things any ideas!
Yes it is DOHC and water cooled, but is not variable valve timed like some pulbications say.
From www.fiatbravo.net :-
115 16v
ENGINE
No. of cylinders, layout 4, in line, front, transverse
Bore x stroke (mm) 82 x 82.7
Capacity (cc) 1747
Compression ratio 10.3 : 1
Max. EC power: kW (bhp)
At rpm 83 (113)
5800
Max. EC torque: Nm (kgm)
At rpm 154 (15.7)
4400
Timing system 2 OHC (toothed belt) with hydraulic tappets
Fuel system electronic MPI phased, sequential
Ignition electronic, static advance, combined with injection
It is simply DOHC, no variable valve timing. Thats on the Barchetta (sp?).
The haynes manual shows how to strip the head and nowhere does it mention anything about variable valve timing.
I
1
836
K
I
1
6K
stevew
S
M
588
Michael
M
I
2
898
Dark Lurker
