- Joined
- May 5, 2006
- Messages
- 894
- Points
- 214
i'm having troubles after cold start of my Stilo 1.6 (2002) : after starting normal (cold engine / weather) the engine suddenly dies alter driving a few meters, activates the MIL and stores a P0105 fault (MAP sensor).
Just by revving the engine up to 3-4000 rpm i can prevent it cutting out again.
After revving it for about 30 seconds the engine keeps running and doesn't cut out anymore and runs fine during warm-up.
After i changed the sensor for a new Marelli sensor(had one as a spare part) the fault re-occurred the next day so i guess the fault is not caused by the sensor itself and is related to the temperature.
Although i found a few posts with fairly similar symptoms i didn't find a clear cause nor a solution for this problem.
Does this sound familiar to someone who had the same problems and knows the cause and the solution for this annoying problem?
Thank you in advance for your help !
