Technical  1.6 bipower p0351 p0352
elektrotechnikas
Greetings from Lithuania! I can't do it anymore!!! Engine cuts out... in accelerating or deaccelerating in gas or in petrol.
I bought it with bad engine head gasket, rebuilt all motor. I changed ht leads, spark plugs, ignition coil, ecu, cleaned ALL contacts... FES showing p0351 p0352. Swaped map, throttle body from my other multipla and nothing hapened...
Befor changed everything few times showed knock sensor faults and p0352 p0352...
What can i do? Please... help ����
This sounds like a basic ECU problem - I'm not the best person on petrol so don't shoot me!
Maybe (only guessing here) the new units are not 'talking' to the old ECU - try putting the old gear back on and see how it goes
All the best
All the best
What do you mean "old gear"?
I have just read your post again - I can only say that one of your parts is not compatible .
As I said - petrol is not my beast, I prefer diesel, I was only trying to help.
Good luck.
elektrotechnikas - you may not get much response to your query here, as the BiPower was never sold in the UK. It may be worth signing up on an Italian forum and put your question through google translate. The Polish Multipla forum might also be worth a try.
