(CZ)enda
Established member
- Joined
- Aug 15, 2005
- Messages
- 822
- Points
- 171
I have two marks on the crankshaft timing belt pulley - a dash from its centre and a dot. Their location is, say, 3 and 6 o clock.
The dot mark is not mentioned in any of the manuals available to me (incl. Haynes and Porter)
ATM, the setup is that the dot is at 6 o clock position when the camshaft notch is aligned with the protruding mark on the plastic cover.
There is a "double line" mark on the flywheel located against 0° mark on the bell housing (i.e. it looks like a TDC mark) at this crankshaft position, however, I noticed there is another mark on the flywheel - a notch the color of which is doubtful, possibly white/yellow (it was getting dark
Is the existing setup correct?
The engine is plain 1,4 i.e., code 160.A1.046.
