Hi all, new to the forum & 1.3 engine looking for some advice.
I have bought a 500 1.3 that was suspected timing chain due to rattle noise and non start, it would fire then cut out. Turns out this is because there was barely any oil left. However now the car will start and idle but will not rev at all unless I disconnect the oil breather pipe from the back of the intake. It's blowing quite a lot of gasses & oil out of the pipe. I'm not sure if this is normal or the piston rings are likely knackered? I'm struggling to understand why the throttle won't open though? Could the pressure be that high that it would stop it opening?
Any suggestions much appreciated cheers
