Hi!
I have a 2007 Punto 1.3 Multijet. Apparently someone before me diagnosed a bad turbocharger and two faulty injectors. It was already taken apart so I couldn't see it for myself. I replaced the turbo and all 4 injectors, checked everything else as good as I could, also gave it a maintenance service.
The problem now is something I've never experienced before, which is why I'm clueless: turbo pressure arrives very late. It's extremely sluggish for a long time, no pressure at all, struggles to get up to around 3000-3200 rpm, then it kicks in. Otherwise the engine is running smooth, no fault codes. However I tried reading some live data and it just makes no sense whatsoever, for example the air flow sensor's data and the engine rpm shows the exact same value (over 53000 kg/h and rpm...) which could indicate faulty sensors and perhaps these are the default "no value" values, but they're not constant, also if these values were true then it certainly wouldn't have a smooth idle and I'd get fault codes.
Before reading the live data, I was thinking that the problem might be the lack of backpressure as there's currently no exhaust beyond the DPF, but now with the live data in mind... I'm not sure. I'll see as soon as the new exhaust arrives, but in the meantime I'm interested in your opinions. I was also thinking about resetting the ECU to factory, I know for a fact that they've used the car with the bad turbo for a long time so maybe it just needs to relearn the factory settings.
Feel free to shut down my bad ideas, evidently this is not my area of expertise, it's not something I usually do. Any advice or idea is welcome.
