So some of you may remember the custom induction kit I built for the 1.9 Mjet Grande Punto.
https://www.fiatforum.com/grande-punto/223798-diy-bespoke-custom-mjet-induction-kit.html
This weekend I decided to have some fun with the 500 and see what I could do.
First steps were to take some measurements:
Oil Breather 23mm OD
MAF Sensor 70mm OD
Turbo 40mm OD
Bumper Cut Out 56mm ID (near where the factory air feed starts behind the bumper)
After this was done using MultiECUScan it was time to take some air flow measurements for comparison. First with the factory system intact and then with a single cone air filter fitted directly to the MAF sensor.
The pipework from the turbo other than a flat spot changes size and shape quite smoothly so unless its in the way for routing I see no need to replace it at present.
As we can see from the data gathered and the graphs above, the factory airbox is rather restrictive. With the cone filter we see approximately 100mg/stroke more air taken in right across the rev range. There's the potential that if a double cone filter is used that will rise a touch further but space wise there's nowhere for it.
Next steps are to decide where the filter should live and then to pipe back toward the MAF. A BMC CDA (Or cheaper clone) might be the way forward and would fit after a 45 degree silicone bend in place of the factory air box.
MAF Sensor 70mm OD
Turbo 40mm OD
