Hey all
Noticed that the car was taken its time to heat up, was sticking at the first 8th point for longer then normal, before it would move from their to the usual just under half point, but shortly after when getting upto speed it was showing signs of overheating, went as far as the first dot above the half way, before settling down to half again when taking it easy.
Had the water noise from behind the dash area I have noticed over the past two days as well.
Also had no heat coming from the heater today.
Saw some other threads on here mentioning about the termostat and to bleed the system. Where is the Thermostat located and the bleed points, where would these be on the 1.2 ?
