General Indoor Handle, problem open - Stilo
clicky
Hello, Fiat Stilo 5d 85kw hatchback, the driver's door is going to open from the inside up to 5-6x or sometimes not at all. It started yesterday, last winter I had a similar problem, but in the summer it was good. Looks like it depends on the weather. If my car is locked from the inside and I pull the key, the cup pops out and the car unlocks but the door doesn't open to me anymore. Has anyone had anything similar? Thanks for help .
Not sure if I'm understanding the issue here. But if it's the case that the pull handle on the driver's door doesn't release the catch to open the door, I had a similar thing which was resolved by dismantling the door card and the pull handle etc and simply rotating the pull handle (with the cable still attached) a few times to tighten it up and then reassemble it all. Worked a treat for me and still fine. Think the problem us due to the release cable stretching with use over time and rotating it tightens it up.
Hope that helps.
Cheers.
Haven't had this happen before. Last winter my door cable snapped, but that then was a permanent problem and you couldn't miss it happening (it literally felt like something snapped when I pulled the handle).
Since your problem happens only some times I would guess it has to do with your central locking.
