Thanks Ralph and Davren
This is on the back of the recent discovery of a large twist and hole in the gaiter on the driver’s side of the rack when I was having a mooch around underneath looking at some bits of the suspension, as mentioned earlier in this thread. Dunno how long it’s been like that, but not mentioned at MOT time in June. Poked a finger in the hole and it seemed very dry and made a mental note to self to do something about it sooner rather than later, and in the meantime have been building up to doing the wishbones, and probably the track rod ends, on both sides, which are past their best.
However, co-incidentally (or maybe not) during the week last week the steering developed a reasonably vague stiffness, not overly obvious, but mainly noticeable in a reluctance for the steering to re-centre from around the “ten to” and “ten past” positions. Don’t think that it is power assistance related, since turning the steering wheel to make the turns through the full range still feels as it should. Adding two and two to get five, I concluded that this was something related to the burst gaiter, so have been on the trail of what to do about it, hence the enquiries about grease (I’ve got a tub of the graphite stuff in the garage, as well as the type that goes in the driveshaft boots). At the weekend, I scooted some silicon grease into the boot, which will probably turn out to be the one thing not to do, but coming up the road this morning, the steering did feel a bit easier, if not totally perfect. I’ve got a replacement boot coming and had presumed that I would need to put some form of lubricant into it (I see that some of the boots on the market come with CV grease as part of the package?). Any thoughts on this greatly appreciated, as always. I’m hoping that I’m not looking at the need to replace the rack, which as far as I can make out is a fairly big job requiring the sub frame to be lowered ….?, probably something not DIY for me and so would be a bit of unwanted expense at the garage.
