zugreveles
- Oct 12, 2012
- 7
- 3
First sorry for my english, but you will understand me i guess
hi to everybody, i have stilo jtd 115 2004. when i buy this car before 4-5 years the car was rocked with also good consumption... Now i have some problems with the car. The problems started about 1 year ago. I noticed some “leaking sound “ when i was reving, the car was losing power(no more rocked), and good amount of black smoke when i push hard. Consumtion started to be vary bad. Winter times goes to 12l /100. and summer 8-9l /100. one time when i open the hood i noticed that the engine cover is a bit oily... then i found that the intercooler-engine pipe was broken and leaking... I fix that plastic pipe now and there is no holes and no leakings. also no more oil leaking from pipe. Take it to ride and now its better. That “leaking sound” has gone and car now have more power then before... (but not like a good times) also i check the consumption, i think its a bit better but its too early to know.
about the power now... the car now have some power back, but i still miss some horses from that JTD 115 beast!! its not the same power now and before 2 years.. i was running with broken intercooler pipe and all that bad symptoms about maybe 1-1,5 years... is there possibility that my car now is clogged and maybe need to “blow out” to reveal some more HP ?
problem 2: on a highway, when i push hard on the pedal, on 2500 RPM there is always instant power loss(turbo goes off) and engine failure message on dashboard. after that the car is running without turbo and its slow like hell. Then i need to take out from gear and put it back again and turbo goes on again till 2500rpm... on 2500rpm goes off again with that engine failure msg. thats so anoying...
and why is this stroke into this black rubber on the photo ? what is it?
