The release arm inside the car seems to be just a press fit on its axle. I managed to knock mine out by accident when I was vaccuming the car, so you should be able to just pull it off.
The axle is fitted transversely.. so you need to pull the lever in the direction of the opposite door's door hinges to remove it. The cable nipple can be removed once the arm is off.
Ralf S.
