Hello,
I just bought a Stilo Abarth with some electronical issues. It was very cheap, so I didn't care about it, but now I can't find the root of its issues.
It has the typical loose connection error, but after reading all of the other threads and trying some stuff, the car is still inoperatable.
As soon as you turn the key to MAR, it's giving me a lot of errors. ABS, ASR, ESP and gearbox failure, paired with loose connection and car safe (sorry, don't know what it would show in English, in German it's "wagen sicher", so immobiliser). Trying to start the engine, it will crank but not ignite (because of immobiliser error I suppose).
Sometimes the engine will start (maybe a 1/20 chance), but will shut itself off within 30 seconds with all the errors again.
Guy before me said it started when putting a new battery in, but I don't know whether that was the truth.
What I tried so far:
- tried two different, fully charged and rather newish batteries
- disassembled both fuse boxes and cleaned all the layers and connector pins
- disconnected all connectors (including D4) in the battery area, spraying them with Nigrin contact cleaner from the inside and letting dry for a day
- checked fuses and relays
- checked the earthing points I could see and reach from the top. Only one I couldn't get to was the engine earth next to the airbox. Seems I should easily get there from under the car, but didn't have a jack with me
So where should I go next?
I already ordered some fiat diagnostic interface and new/additional grounding lines, but they didn't arrive yet.
I'm running out of ideas...
