nemilosul01
- Nov 21, 2018
- 3
- 1
Hey i am new and i just buyed my second stilo 1.6 16v 2001.
And i have a problem that won't let me rest.
The problem is that when the engine is cold no matter of outside temperature the engine won't start ONLY if i spray fuel or put half my hand to suck less air in throttle body for like 20 seconds than car stays on idle but only after 1 minute i can press accelerator pedal without engine dying.
I came to realize that the spark is good but the car does not get fuel when cold when is warm it RUNS like new.
Things i had done so far:
-checked fuel pump pressure that is about 3.5bars exacly like the other stilo.
-changed spark plugs with genuine ones ( solved lots of problems)
-swamped the entire kit of electronics from the other stilo to check if the ecu was the problem ( swamped ecu, BCM and the cip of the key and it had the same problem)
-i changed 3 water temperature sensors ( 1 original, 1 facet, 1 vernet)
-swamped throttle body from the other stilo.
-swamped MAP sensor from the other stilo and still i have the same problem.
My big question is: What does say to the ECU when engine is cold beside temperature sensor and MAP sensor?
The old owner of the car sold the car with this problem because nobody found a solution.
