Old faithful 03 plate StiloJTD not running too well on way home last night, engine suddenly feels really lumpy 1200 - 2000rpm, not great power, but goes OK when you put the foot down up to a point, checked injectors, vac lines, egr defo' not problem cause it's blanked, been getting engine warning light @ around 3000 - 3200 RPM when accelerating hard under load (eg going up hill) lately so decided (while under it this morning anyway) to move the turbo overboost control valve up away from all the road spray n crap & re-piped the vac hoses, the waste gate actuator looks OK not losing vac / is moving in & out when I pull the vac line off, but still getting same warning light when putting the foot down under load, sure this is overboost? so valve might be goosed, TBH I'm not really sure how this thing is supposed to behave - you cant see it under load & drive at the same time; wonder if this valve could cause a lumpy running at low rpm? feels like running a cylinder down but when I pull off each injector cable a massive difference - not not an injector, might just be a batch of poor diesel? so put in some posh v-power diesel & some injector cleaner & have taken it a run up the bypass giving some juice - made no apparent difference, went well enough with the pedal to the floor but then back to running like a mini dump truck at normal driving speeds at 30 mph 3rd or 4th gear.
I'm now thinking diesel filter (power loss) or Crankshaft sensor (lumpy/timing related?) Any thoughts, think I'm on the right track here?
