- Dec 9, 2004
- 541
- 77
Hey ppl,
I took my Abarth on our local racetrack yesterday (Killarney), and thought I would post a couple of thoughts I had about the car...
Firstly, a map and also some details about the track:
Track length: 3,267Km (2,03mi)
The track has 5 corners, which in order are: Conti, Engen, Shell, Sabat and Vodacom.
The last corner before the main staight (Vodacom) is banked at quite an angle, so even though it is the sharpest corner, it's by no means the slowest.
It was an open day at the track, which means you pay R80.00 (£7) and you get to go out on the track as many times as you like.
The way it worked was that there were only 6 cars on the track at any given time. You start out of the pits in 15 second intervals and then get 5 laps of fun After doing 5 laps you go around the track and enter the pits and fall in the queue of cars waiting to go out again.
Now about the car...
I found that the car handled great for the first 3 laps, then it started to understeer more and more. The warmer the tyres got, the less grip I had... what made it worse was that because the car has ESP, it "helps" you through the corners by individually applying brakes on the 4 wheels... this causes the brakes to overheat and start fading when you really need them.
The brakes got so hot, that halfway through the 5th lap, they would start smoking and hitting the brakes didn't really slow the car down all that much. The vibration was also very bad.
But in saying that, the car is really not so bad around the track. I managed a top speed of 200Km/H (125mpH) down the back straight, and 180Km/H (112mpH) down the main straight.
I went through most corners at over 100Km/H (60mpH), and I found I could keep my foot flat right through the corners. (If I even thought of lifting off the car would oversteer because of the ESP)
I overtook a couple of Golf GTi's (Golf mk3 and mk4), and even thought I could keep up with a BMW M5 (with supercharger) around some of the corners (until the guy had enough of me and put his foot down). I tried to keep up with a Noble m400 coming out of the last corner, but by the time I reached the start/finish line, he was already exiting turn 2
(Man that 3.0 V6 is fast!!!!!)
The most amusing thing about the day was my fuel consumption:
25l/100km or 9.5 mpg
I covered a total of 74Km (46mi) and used 3/4 tank of fuel. I now need new brakes and new tyres... keep in mind my car has only done 14,700Km (9,135mi) ....
But it was worth it and I would go do it again
