bushellmatt
- Feb 17, 2014
- 1
- 1
Hi, my first post and far from mechanical minded so bear with please. I have a fiat stilo 16 v 1.4 on a 04 plate and 100k on miles.
3 months ago my head gasket blew and after taking it to a garage the problem was caused because it had a cracked cylinder head. After 3 months of sitting on my drive managed to get a recon cylinder head and new head gasket replaced. When driving it from the garage went to brake and peddle went to the floor and was no pressure on the brakes. Vehicle slowed but after about 20 yards, tried again after picking up speed and braking the same thing but works fine if i pump the brakes ( poss air in brakes). At the same time dash came up with low oil pressure warning. Had the car recovered back to garage and they are saying wouldnt have been the work carried out by them and probably needs a new oil pump or sensor. They did a pressure test and it read 60 psi but when reved to 4000 rpm went up to 90 psi and when released dropped to 30 psi and remained there. Not sure if thats good or not. But before i spend more money on oil pumps and sensors would be anything to do with having to slam on the brakes to begin with.
Also when they did the test it was stationery and did not give the warning. Only happens when driving. Any help would be gladly recieved.
