you probably will hear the electric throttle body which is held open by a rather high frequency Pulse width signal supplied by the ecu.
This means the voltage is switched on and off very rapidly and the on-time determines how far the throttle will open - this is checked by the ecu using the signal of the potentiometers inside the throttle body.
This is normal and not a fault.
