Hello
Today driving on the motorway i was doing 60mph and then when i put my foot down i had no power. I had my foot flat to the floor and i was only managing about 30mph, so i pulled onto hard shoulder and switched off engine. I started it again and tried to pull away but stalled very easily. Anyway after a few miles of struggling to get past 40mph i pulled over. I called the RAC out and he reckons its the egr valve. On two diagnostic machines it has flagged up a problem with the valve. Does this sound like the egr valve has finally packed up? A local auto electrician also reckons it is. However he won't just replace the valve. He wants to put it on a diagnostics, check engine over and then probably replace the valve. Is all that worth doing if people suspect its the valve? Thanks. Phil
