Kennif Fiat
- Mar 24, 2010
- 42
- 13
Hi all,
I posted back in May this problem when I had juddering and slip, the juddering went away,but I still have clutch slip in my 1.6 sport. It started after a few thousand miles after diff was repaired. I refitted the box using a new clutch kit from Euro car parts.
I did try bleeding/letting out oil to change the bite, I thought it worked at first but it doesn't seem to change the pedal bite and when it's warm slipping returns.
I read somewhere that the 1.6 stilo clutch bite is marginal.
When the pressure is relieved or the slave cyl is removed the operating lever moves away more which I assume would increase the bite.
I don't really want to take the box out again, can anyone please help with a solution?
Thanks regards ken
Thanks regards ken
