Thread Tools
Old 18-05-2011   #1
New Zealand
2002 stilo abarth
hi ,I have 2002 stilo abarth and am hoping for some help.
Does anybody know how to reset service reminder?
Secondly i think i have an electrical problem.have had issues with esp asr abs warnings ,and now main screen is flickering and losing colour,but apart from that car is awsome.thankyou in advance
Thomo
thomo is offline Reply With Quote Quote
Old 18-05-2011   #2
Re: 2002 stilo abarth
You might need a new battery. Take taking out your battery and try fully charging it and make sure the battery terminalsare clean/
tony_m is offline Reply With Quote Quote
Old 18-05-2011   #3
More ICE Please
volxstu's Avatar
volxstu has donated!
Fiat Ecu Scan may reset service reminders. Young have to wait for one of the pros to confirm that.
Esp / asr failures etc sounds like flat battery although that it just heresay from the forum. I have had 3 fiats including 2 Stilos and never had probllems when the battery get tired. (my batts get well used to say the least)
Car Audio Goodness at its best for sale.
http://www.fiatforum.com/classifieds...?product=28141
volxstu is offline Reply With Quote Quote
Old 18-05-2011   #4
New Zealand
thanks for help.had battery checked and its fine
Old 18-05-2011   #5
Yellow Peril has donated!
The service re-set thing has been covered on here numerous times before and AFAIR the conclusion was that it can only be done at a FIAT dealer (more's the pity).
I've just learned to live with it. I know my car's been properly serviced and that's what really matters...
Phil
Yellow Peril
Then:Yellow Stilo 1.6 16V 3-door - not quite standard
Now: Red Stilo Abarth Schumacher GP Prodrive - modded for function over form...
Yellow Peril is offline Reply With Quote Quote
Old 18-05-2011   #6
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
The service indicator can be reset with the registered version of FiatECUScan.
www.fiatecuscan.net
How did you test the battery?
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 19-05-2011   #7
New Zealand
i just got the auro electrician to check it .what should i be doing
Old 19-05-2011   #8
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
If an auto-electrician has tested it, I'd assume it was done correctly, however, Stilos are known for electriclal problems caused by a low power battery.
To avoid most of the common problems it needs the biggest, highest power battery you can fit in the battery box.
Old 24-05-2011   #9
Quote Originally Posted by Davren View Post
www.fiatecuscan.net
What cable do you need to hook up a laptop to the fiat ecu and where is the conection point on the fiat??
Old 24-05-2011   #10
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
To reset the service indicator with FiatECUScan you would need an ELM327 (version 1.3 or later) interface and cable.
The 16 pin diagnostic connector is at the top of the dashboard fuse box behind the cover in front of the driver's right knee (for RHD cars). The cable would need to be modified by soldering some of the pins together to connect to the various ECUs on the Stilo.
Alternatively, Gendan sell the ELM327 interface, cable and a set of adaptor cables so you don't need to do any modifications. http://www.gendan.co.uk/product_FESHW.html
Old 24-05-2011   #11
Crikey! Have you seen the price they're asking for those leads?!!!
Phil
Yellow Peril
Old 24-05-2011   #12
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Quote Originally Posted by Yellow Peril View Post
I thought 74.95 a reasonable price for the ELM327 v1.4 interface and cables, a VAG-COM cable and all 3 of the adaptor cables including postage.
They also sell just the 3 adaptor cables for 18.95. http://www.gendan.co.uk/product_FESCBL.html
Handy for anyone who's not happy about soldering.
Thread Tools
