- Jan 19, 2011
- 5
- 2
Hi guys,
The nearside headlight bulb went and so Mr Bing changed it by removing the battery etc. After reconnecting the battery, not only does the bulb not work on full or high beam, the indicator in the same cluster isn't working properly when the light is on full/high beam but works fine when the light is on side or off. It clicks like mad from the inside of the car (not sure that's relevant or not).
Also, the windscreen wipers and the fan no longer work.
Any ideas on what the problem could be caused by?
Thanks,
Helen
Thanks,
Helen
