Thread Tools
Old 17-04-2010   #1
12[X] has donated!
sticky throttle?! Only when aircon is on 0_o
Ladies and gents.. need some help once again (on an off note.. if anyone is considering driving to London without prior experience or training: almost had 2 accidents tonight + 2 people jumped under the car <have managed to avoid them though> thatís London for you half the drivers and all the pedestrians are drunk on a Saturday night.. you donít want to know what is going down each Friday night )
Rt thanks for reading, as always, sooo onto the problem.. Itís been rather hot in the traffic today.. so kicked on the aircon (works a treat.. though iíve a constant P1531 fault code logged.. been there since as long as i can remember i.e. since acquisition of the code reader back in 2005) anyhow.. all is nice and cool.. happy days then I get out of traffic and stop at a light.. And sit there thinking why is some idiot revving his/her engine only to realise it is me (well my car!!). The engine was at about 3000 rpm when i pushed the clutch in to coast to a stop.. and it stayed at 3000 rmp after stopping.. then, after about 5 seconds, it dropped to 1900.. stayed there for another 5 seconds and went back to normal.. It kept doing that (when stopping in this way) as long as the aircon was on.. iím baffled?! Any ideas?
12[X] is offline Reply With Quote Quote
Old 17-04-2010   #2
sixpotman has donated!
Re: sticky throttle?! Only when aircon is on 0_o
P1531 Over or under pressure on aircon
system. Air signals ecu to increase engine revs
so sounds like it don't like something and causing
too high a revs.
John
Thanks 12[X] thanked for this post
sixpotman is offline Reply With Quote Quote
Old 18-04-2010   #3
12[X] has donated!
thx, i've never re-gassed the system (8 years ) that could be an issue indeed. However, according to my docs 1531 is aircon relay - cansome one please confirm and advice (yes re-gas is cheap but i've no cash to waste @ all eek)
Old 18-04-2010   #4
Netherlands
With AC on, the flap in the throttlebody has a different position. TB clean?
gr J
"Look for the ridiculous in everything and you will find it". - Jules Renard
A3jeroen is offline Reply With Quote Quote
Old 18-04-2010   #5
12[X] has donated!
As clean as it was when the car rolled off the production line! Have cleaned it thoroughly 2 weeks ago with ample amounts of carb cleaner, rugs and a toothbrush to get to the pivot points (besides a dirty TB should affect it with aircon off too?!)
Old 18-04-2010   #6
Netherlands
Yeah but with AC on it would be slightly more open.
But if it's clean....... Nema Problema.
gr J
Old 18-04-2010   #7
12[X] has donated!
alas, that is why i'm seeking inspiration.. perhaps someone here experienced a similar fault and knows how to fix it (well.. one can hope)
Old 18-04-2010   #8
Disconnect the battery for half an hour then reconnect
and do the relearns. Also check the temperature sensor
is sending the correct temp. May be the engine thinks it's
on choke with extra revs for the aircon being on.
P1531 can be a number of things mine shows that with no
gas in the system. Yours shows it with the system running.
John
Old 19-04-2010   #9
12[X] has donated!
not done a battery reset for about a year (been using eobd interface) might as well give it a go (though not holding my hopes up as i have done a relearn/reset after cleaning the tb and a relearn before the journey)
Thread Tools
(G) Sticky throttle dhtmo Cinquecento / Seicento 4 29-08-2008 16:16
Need something sticky... EazyE16 Leisure Lounge 18 09-08-2008 01:11
a sticky end custard Leisure Lounge 13 29-08-2007 16:37
(T) 105 JTD - Where is Throttle Body / Throttle Potential Sensor b1gduk Marea 4 22-01-2006 20:53
(G) How about a servicing sticky? StiloBoy Stilo 48 08-11-2005 20:51
