chrisghz
Hi guys, kinda new to the forum and hopefully someone will know what on earth ahs happened to my car!!
Other than the continuing and now usual faults i get on my now nicknamed "HEAP", like loose connection and engine fault, i had another one crop up the other day which is really annoying me now.
For some unknown reason both electric windows have stopped working. Having downloaded the manual and checked just about every fuse i can see its not the fuses!
I have also trawled the forum for a similar thread but no luck.
All the lights on the buttons on the driver door panel are on, i can still adjust the electric mirrors and have tried the usual cleaning the door connector but all to no avail. :bang:
Could it be a problem with a relay where every that might be located or a computer fault!!!
Also it might be nothing but the driver side headlight has died, but i couldn't be sure if it was as the same time but they were only all replaced a couple of months ago....(i should really replace it).
Any help would be very much appreaciated!!
