im Axle Specialists
Old 07-01-2010   #1
Ireland
JTD 80 tick tick sound
I started to notice some rattling from under the bonnet recently. It wasn't all of sudden thing but started gradually. How could I describe it at best. I can hear exactly same sound as from old petrol junker which sounds like diesel.
It sounds like louder tick tick tick sound and the frequency follows the revs.
The sound is more noticeable when the engine is warm and the normal diesel noise is reduced and when accelerating from low revs and low speed. It can be heard also when the clutch pedal is depressed, so I presume it's not clutch or gearbox related.
And besides that sound the engine runs fine.
The engine has 120k miles and timing belt was replaced at 92.
Any idea what it could be?
coffee is offline Reply With Quote Quote
Old 07-01-2010   #2
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Re: JTD 80 tick tick sound
When were the valve clearances last adjusted?
They should be checked and adjusted, if neccessary, as part of the service but as it's quite a lenghty process and involves a special tool, many non dealer garages don't bother.
Dave.
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 5 of 215/45-17 Alloy Wheels
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 07-01-2010   #3
Ireland
Quote Originally Posted by Davren View Post
Dave.
Thanks for reply.
Truly I have no idea. Probably long time ago if ever.
Old 07-01-2010   #4
Stilo JTD 115BHP
punto60_s's Avatar
punto60_s has donated!
I noticed this in the service schedule does anyone know how much it costs?
Navy, Fiat Stilo JTD 115 bhp, 17' alloys, Side Skirts, Spoiler - Excellent Fun!!
punto60_s is offline Reply With Quote Quote
Old 07-01-2010   #5
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Checking the clearances is included in the service schedule but if they need adjusting extra and depends how many need adjusting. The new shims needed to adjust them with are about £13 each and there are 8 of them.
Dave.
Old 07-01-2010   #6
It will be your crankshaft pulley. Common to fail on a JTD. Cost about £80, and quite easy to change.
Change it soon before it breaks and does serious damage.
john55 is offline Reply With Quote Quote
Old 07-01-2010   #7
Agree with john 55 sounds like bottom pulley, mileage is about right for it.
When it first starts you get the rattle when cold, and as the engine warms up the noise goes, if you turn the a/c on it comes back.
As the rubber centre breaks up the noise becomes permanent.
Easy job four torx bolts.
cris1117 is offline Reply With Quote Quote
Old 07-01-2010   #8
Quote Originally Posted by cris1117 View Post
Getting that belt back on afterwards can be a bit tricky though.
Old 07-01-2010   #9
Ireland
The noise is more evident when the engine is warm. but I will check that as well.
Old 07-01-2010   #10
Itís easy enough to see it if you take off the o/s/f wheel and the plastic cover you can see the bottom pulley.
If the centre rubber looks cracked and you can move it from side to side change it.
I too struggled with the belt, but found an easy way.
If you put the belt around all the pulleys except the power steering, get it to bite on the power steering pulley and turn the engine over with a spanner on the bottom pulley you will see the tensioner slide back as you do it then return when the belt is on, itís a bit like putting the chain back on a bicycle.
The belt looks a bit peed off about it, but itís been O.K for 20k now so no harm done.
One other thought when I did mine I noticed the belt had several lumps out of the contact side, this could also be your problem, especially if youíre like me, apart from oil and filter donít fix it if itís not broke.
(T) Tick over Zak1991 Cinquecento / Seicento 8 31-08-2009 23:11
(G) Tick Tick Tick Tick . . . . "BOOM" sedi_2000 Tipo (Classic) 9 21-04-2009 19:04
(G) tick tick timing slip manic_monkey Bravo / Brava 11 08-03-2007 16:11
(G) tick over problems aridle Ulysse 11 19-09-2004 19:00
(T) tick tick tick Huba Bravo / Brava 1 10-02-2004 23:49
