Old 18-10-2010   #91
Fiats since 1973
johnson550's Avatar
johnson550 has donated!
re: FiatEcuScan diagnostic software
Please also note that by adding the "delay circuit" to Connect Nav you are preventing its detection by either Body Computer or PROXI Alignment procedure.[/QUOTE]
I dont know how these things work technically but I have a connect nav+ retrofitted (followed ins on FF) and all the info shows up on the screen e.g. how many miles left in tank and all that sort of thing.
2007 Stilo Sporting M/Jet 150bhp
2001 Marea Weekend JTD 110bhp now 171bhp (Gone but not forgotten)
http://www.fiatforum.com/garage_vehi..._vehicle&id=24
He who works and does his best
gets his cards just like the rest
johnson550 is offline Reply With Quote Quote
Old 02-11-2010   #92
yellowstilo has donated!
Netherlands
Quote Originally Posted by StiloBoy View Post
Does this mean I could re-program a replacement remote key to work on my Stilo. My current key has stopped working (remote locking).
a second-hand key can't be reprogrammed because the transponder inside has to be pre-programmed to match the PIN-code stored in your body computer.
Theoretically it is possible to read the eeprom contents of the processor inside the body computer and produce a new transponder by decoding the binary file with special locksmith equipment but that's a specialist's job....
A key ordered at Fiat will come pre-programmed and has to be stored in the memory of the body computer with the Examiner tester or other special equipment before it will work.
yellowstilo is offline Reply With Quote Quote
Old 03-11-2010   #93
StiloBoy has donated!
Ah what I meant was get a replacement key and transplant the transponder "grain of rice" and blade over to the working key unit. Then reprogram it to unlock the car with the buttons again?
Does that make sence?
Ex- 53 plate, Stilo 3-door, Sassy grey, newly refurbished 17" Claw Alloys, Avon ZV5 tires, 1.2 Active
http://www.fiatforum.com/gallery/data/500/26348.png
StiloBoy is offline Reply With Quote Quote
Old 03-11-2010   #94
Netherlands
yes, that would make things easier, the transponder would be already known by the body-computer , the blade would be o.k, i just don't know about the RF circuit board - i guess it sends it's own code nr. (apart from the transponder number which is read by the transponder antenna ring around the key lock barrel), i think this will have to be coded to the bodycomputer with a Examiner tester (or F.E.S.?)
Maybe someone already tried your option with F.E.S. ?
Old 06-11-2010   #95
sixpotman has donated!
We have a 54 punto 1.4 sporting, the registered version
of FES and a Gendan Elm 327 genuine 1.3a chip unit
but can only connect to the engine ecu at present nothing else,
although it works fine on a 03 Stilo 1.8.
John
sixpotman is offline Reply With Quote Quote
Old 07-11-2010   #96
Forgot to say I also turned the Indicator flashing on
to flash when the remote Locking is used on the Stilo
too.
John
Old 12-11-2010   #97
Malta
hi all,
I've read about this FiatEcuScan program and it sounds great and want to give it a try.
Can anyone tell me what kind of cable I need for my Bravo TD75 SX?
Thanks a lot
kajl is offline Reply With Quote Quote
Old 13-11-2010   #98
Quote Originally Posted by kajl View Post
hi all,
Thanks a lot
I have just bought a cheap interface off the bay. I will need to do a bit of soldering to link a couple of pins to Investigate my ABS but it should work.
ill update when it arrives . I have gone for VAG kk instead of elm (for reasons I cant explain)
I have already used an ELM which worked fine for the main ECu but it wasnt mine and I had to give it back.
Dancake is offline Reply With Quote Quote
Old 17-11-2010   #99
Soldered pins 1 to 7 on my Cheapo Vag Com cable (8 quid) and got straight into the ABS with free version of Fiat ECU scan!
Front Right sensor inplausible
Front left open circuit.
NB you will need the elm for the main ECU but I tried that before and that works too
Old 22-11-2010   #100
Hungary
Question re: FiatEcuScan diagnostic software
Does this seem legit to you?
http://cgi.ebay.co.uk/CAR-PC-DIAGNOS...item255f0a4b52
And can I use all features of the program with this cable?
Jevge is offline Reply With Quote Quote
Old 22-11-2010   #101
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
It's almost impossible to recommend a lead or interface on eBay because so many sellers are selling cloned items that have been proven not to work at all or without some internal modification.
As far as I'm aware, the only company selling ones that are guaranteed to work without needing any soldering of wires or modification is Gendan. They sell a set of leads, adaptors and a genuine ELM v1.4 interface as in this link:
http://www.gendan.co.uk/product_FESH...ct_information
Or... the complete kit of leads, adaptors, ELM v1.4 interface and the registered version of FES that enables you to connect and use all the functions of FES here:
http://www.gendan.co.uk/product_FESPKG.html
There's also a lot of information about about the leads and what modifications are required to them on Yani's FES forum here:
http://forum.fiatecuscan.net/
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 5 of 215/45-17 Alloy Wheels
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 23-11-2010   #102
yampug has donated!
i bought this one for the elm v1.3a cable and it works fine on my stilo jtd. http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
i've reset my service light and played about with some other stuff, not tried it on the airbag ecu but it does work on the main engine ecu, it doesn't do the steering ecu i use a vagcom one for that which i modified with the extra bit of wire.
yampug is offline Reply With Quote Quote
Old 25-11-2010   #103
robbie-rocket-pants has donated!
I can connect to all ECU's except the airbag ECU through my ELM 327 set-up on my Stilo JTD. I read through Yani's list:
http://www.fiatecuscan.net/SupportedVehiclesList.aspx
So I think that a KKL/VAGCOM cable is the only current way to connect to the airbag. I've sent off for another cable !
Think or thwim
robbie-rocket-pants is offline Reply With Quote Quote
Old 29-11-2010   #104
Stilo JTD 115BHP
punto60_s's Avatar
punto60_s has donated!
Version 2.6 is out with quite a few improvements including the cruise control light for retrofitted cruise control and Proxy alignement.
Navy, Fiat Stilo JTD 115 bhp, 17' alloys, Side Skirts, Spoiler - Excellent Fun!!
punto60_s is offline Reply With Quote Quote
Old 02-12-2010   #105
It's about GO! not SHOW!
Argonought's Avatar
Argonought has donated!
Thumbs up re: FiatEcuScan diagnostic software
Quote Originally Posted by punto60_s View Post
I'm gob-smacked
Will the next feature be body computer alarm activation
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: FALKEN ZIEX ZE912; Oil: Mobil 1 TD 0W-40 fully synthetic
Argonought is offline Reply With Quote Quote
yay ! FiatEcuScan software is looking good.. stylers Tech Talk 6 11-09-2014 12:30
(G) FiatECUscan diagnostic tool topwally Multipla 0 02-05-2010 10:54
(T) Delphi Electric Steering Punto Mk2 with 'Fiatecuscan' diagnostics software Keithn Punto (Mk2/2b) 9 27-04-2010 21:40
(T) FiatECUscan diagnostic tool joipalli Multipla 1 27-04-2010 04:19
Diagnostic software Captain Mike Computing 13 04-03-2008 00:44
